Thread Number: 94589
/ Tag: Modern Dishwashers
2010 Bosch DW trouble... |
Post# 1192498 , Reply# 1   10/24/2023 at 22:00 (186 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Does it display any fault codes? The drain/wash pump running is normal and a part of a calibration process. Fill valve will only be energised after that. |
Post# 1192527 , Reply# 2   10/25/2023 at 10:12 (186 days old) by cfz2882 (Belle Fourche,SD)   |   | |
no fault codes displayed,but if they can be shown by pressing buttons in certain sequence i could check. |
Post# 1192568 , Reply# 4   10/26/2023 at 10:20 (185 days old) by cfz2882 (Belle Fourche,SD)   |   | |
when i checked power at the remote fill valve,a neon indicator lamp was used -i had assumed the valve was 120v,going to use a DVM this time incase valve power is lower voltage or DC. |
Post# 1192673 , Reply# 6   10/28/2023 at 14:35 (182 days old) by cfz2882 (Belle Fourche,SD)   |   | |
checked again ,no power at the valve-valve coil measures at 977 ohms:seems high,but probably DC powered. Float switch/pressure switch seems ok because machine will drain the sump if i fill it. |
Post# 1192686 , Reply# 7   10/28/2023 at 20:34 (182 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1193174 , Reply# 11   11/7/2023 at 18:10 by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What style of pumps does it have? |
Post# 1193179 , Reply# 12   11/7/2023 at 18:45 by cfz2882 (Belle Fourche,SD)   |   | |
seperate wash and drain pumps-both are inverter driven BLDC with no external moving parts-super quiet. |
