Thread Number: 94675
/ Tag: Classified Ad Finds
Frigidaire "Horizon 2000" Washer and Matching Dryer |
Post# 1193211   11/8/2023 at 10:34 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Bless their hearts, WCI really did try didn't they?
Washer: hibid.com/lot/175760637/frigidai... Dryer: hibid.com/lot/175760638/frigidai... |
Post# 1193215 , Reply# 1   11/8/2023 at 11:39 by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1193217 , Reply# 2   11/8/2023 at 11:48 by Maytag85 (Sean A806)   |   | |
Post# 1193218 , Reply# 3   11/8/2023 at 11:49 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1193221 , Reply# 4   11/8/2023 at 12:05 by DADoES (TX, U.S. of A.)   |   | |
Washer 12 cycles? 1) Heavy Wash 18 2) Regular 3) 12 4) 6 5) Sanitize 6) Perm Press 12 7) 8 8) Quick Wash 9) Knits/Delicate 6 10) 3 11) Timed Soak 12) Prewash |
Post# 1193222 , Reply# 5   11/8/2023 at 12:13 by DADoES (TX, U.S. of A.)   |   | |
Post# 1193223 , Reply# 6   11/8/2023 at 13:06 by Repairguy (Danbury, Texas)   |   | |
Post# 1193226 , Reply# 7   11/8/2023 at 13:36 by bajaespuma (Connecticut)   |   | |
IIRC the "SANITIZE" setting on the 1-18's was like the "SOAK" cycles on early Filter-Flo's also positioned within the Normal cycle's rinse period. In other words, bullshit. It was one more "perk" they could claim in the brochures.
With the Frigies, you put Clorox in the bleach dispenser and set it to SANITIZE and the idea was you could sanitize the tub without running a full cycle and feel safer if you were a moron.
With the FF's one did essentially the same thing and gave your laundry what was more accurately described as a Pre-wash without the convenience of an automatic segue to the WASH cycle. Eventually GE called it an "Activated Soak". As if the user couldn't just run a cycle and interrupt it and allow the laundry to just sit there and soak while the machine was deactivated. And I think users couldn't deactivate the Solid Tub washers for a soak because the water would drain out of the washbasket through that little hole in the bottom of the tub into the outer tub.
I remember setting the dial on our 1962 Perf tub machine at "SOAK" one time because I thought maybe there was some sort of secret switch in the dial that would work if one started it at that exact point. Felt like an idiot.
The GE bullsh*t was introduced before Enzyme soak products were on the market. |
Post# 1193231 , Reply# 8   11/8/2023 at 14:52 by DADoES (TX, U.S. of A.)   |   | |
Post# 1193269 , Reply# 9   11/9/2023 at 06:21 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Those washing machines were just awful did not hold up well if they were used much, the dryer was average it was just a Westinghouse. They were repairable, at least.
Looks like they had a badly adjusted gas burner, or it was operated in a very dirty environment, where is Bradford White when we need him, I could just hear his comments on it, lol John |
Post# 1193272 , Reply# 10   11/9/2023 at 07:06 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
