Thread Number: 94685
/ Tag: Vintage Dishwashers
What is this vintage dishwasher with propeller in bottom |
Post# 1193310   11/10/2023 at 05:15 by Adam-aussie-vac (Canberra ACT)   |   | |
Hey guys, I found this on Facebook marketplace. The seller mislabelled it as GE instead of GEC, is vintage it’s good looking apparently it works and I want it |
Post# 1193314 , Reply# 1   11/10/2023 at 06:32 by christfr (st louis mo)   |   | |
Post# 1193366 , Reply# 3   11/10/2023 at 22:53 by Adam-aussie-vac (Canberra ACT)   |   | |
So I’ll be getting it |
Post# 1193434 , Reply# 4   11/11/2023 at 21:31 by Tomturbomatic (Beltsville, MD)   |   | |
That lower rack reminds me of the bed pan washers by Hobart we had in our hospital. |
Post# 1193467 , Reply# 6   11/12/2023 at 11:24 by Tomturbomatic (Beltsville, MD)   |   | |
When you get access to the machine, you can do some research on the model number and see what the machine is meant to be used for. |
Post# 1193477 , Reply# 7   11/12/2023 at 13:57 by Adam-aussie-vac (Canberra ACT)   |   | |
There’s no drainpump as it just open the valve, and there is no heater either. At least from what I’ve physically seen with the photos, so I’ll have a look on Friday |
Post# 1193587 , Reply# 8   11/14/2023 at 02:42 by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 1193588 , Reply# 9   11/14/2023 at 05:38 by Adam-aussie-vac (Canberra ACT)   |   | |
Drainage connections when it arrives, at the moment, I’m not sure if it has a heater, but it’ll be hooked up to hot water regardless |
