Thread Number: 94689
Check out your washer hoses, folks |
Post# 1193326   11/10/2023 at 13:58 by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
Was going to be gone for several weeks, so turned off the faucets to the washing machine where I noticed the hot water hose was blistered and had some turgid bubbles in the outer skin (these were black vinyl/rubber, not woven-metal clad).
Interestingly, when I took them off, they each had printed on them a manufacturing date of 2014 and a "replace by" September 2020. Fortunately no leaks--wouldn't have been too bad a mess as they're in the unfinished part of the basement. |
Post# 1193331 , Reply# 1   11/10/2023 at 14:40 by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 1193341 , Reply# 2   11/10/2023 at 16:22 by ea56 (Cotati, Calif.)   |   | |
I shut off the valves too after each use. To save the angle stops from wearing out I screwed on brass 1/4 turn shutoff valves like you can use on your outside faucets at the suggestion of Yogi (Martin) This works perfectly.
Eddie
