Thread Number: 94698
/ Tag: Vintage Dryers
70s lady Kenmore gas dryer is not heating |
Post# 1193418 , Reply# 1   11/11/2023 at 15:24 by eronie (Flushing Michigan)   |   | |
New coils needed. |
Post# 1193530 , Reply# 2   11/13/2023 at 10:48 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Definitely a valve coil or possible bad valve itself these older dryers if the valve coils go bad, we replace the entire valve assembly with the newer style compact valve, coil burners.
You can either buy a new complete valve assembly at considerable cost or grab one from a newer dryer And retrofit it to your dryer to keep your great old dryer running. John |
Post# 1193537 , Reply# 3   11/13/2023 at 11:39 by Maytag85 (Sean A806)   |   | |
Post# 1193875 , Reply# 4   11/18/2023 at 20:04 by Srod2286 (Los Angeles )   |   | |
Any idea where I can order the new valve assembly that will fit here? The wiring is diff would the same connectors fit? I’m open to any suggestions. This is how it looks |
Post# 1195302 , Reply# 6   12/13/2023 at 05:48 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
For your 70s lady Kenmore dryer, is part number 279894, the wiring harness may not match up perfectly. You can just splice the two wires.
Changing the igniter will not do any good the igniter resistance does not react with the valve coils it has nothing to do with the resistance of the igniter. As long as the igniter gets nice and hot as yours is doing it is fine. Once the igniter gets hot and it cycles off, the power goes to the secondary gas valve coil which is what has failed on your dryer. John |
