Thread Number: 94756
A806 |
Post# 1193962 , Reply# 3   11/20/2023 at 09:03 by thatwasherguy (Kentucky)   |   | |
This is most often caused by a failing tub seal. You can still get both parts aftermarket, although only the bearing is available OEM. The tub seal is part number 6-2095720, and the bearing is part number 6-2040130. You may even be able to temporarily get your current one going by shooting some oil into the wick with a syringe.
Hope this helps, Thatwasherguy. |
Post# 1193975 , Reply# 4   11/20/2023 at 11:25 by Billmk1963 (Vancouver BC)   |   | |
Not sure what the wick is newbie at this. |
Post# 1193978 , Reply# 5   11/20/2023 at 13:12 by Billmk1963 (Vancouver BC)   |   | |
When I look for part 6-2095720 it is no longer available at the 2 Canadian sites I’ve looked.Bearing is |
Post# 1193981 , Reply# 6   11/20/2023 at 13:54 by Billmk1963 (Vancouver BC)   |   | |
Sorry found that after market one on Amazon. |
