Thread Number: 94759
/ Tag: Vintage Dishwashers
Not sure what is going on. |
Post# 1193977   11/20/2023 at 13:04 by rpms (ontario canada)   |   | |
Kinda think this dishwasher is more than 20 years old?
Serial # 665 1578 4300 Kenmore. I bought the dishwasher used from an elderly lady. New owners wanted to update the kitchen. It is not Almond but maybe bisquet? Been a great dishwasher so far. The laundryroom and kitchen are about 6 feet from each other. I was doing a load of laundry and the washer has a tendency of pushing water up the kitchen drain. Not a lot but a bit. The same day the dishwasher was going and both hit the drain cycle at the same time. Big gurgle and lots of water in the sink. I should have shut one off but didn't. Ever since then the dishwasher is acting weird. It will go through each cycle but the clean light does not come on. The pots and Pans light goes on or it flashes back and forth to the rinse and hold. I unplugged it and tried again. Everything works but the lights are weird. Looked up how to reprogram it but there is no heat setting button to go to. If you press a cycle it lights up but the cancel button won't cancel. You have to push start and then cancel. |
