Thread Number: 94996
/ Tag: Modern Dishwashers
Miele Dishwasher Long Cycle Times |
Post# 1196430 , Reply# 2   1/2/2024 at 06:01 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I am not an expert on Miele dishwasher however, in general, it’s a very poor idea to use the one hour cycle on any modern dishwasher on a regular basis.
It just doesn’t clean sufficiently or reach the proper temperatures, etc.. We see a lot of US built dishwashers that turn into a horrible mess because people always want to use that one hour cycle, it usually uses more water and doesn’t reach proper temperatures and you get all kinds of buildup in the machine and nasty smells out of them. Maybe your dishwasher is trying to correct the problem that been caused by the short cycle, the short cycle should only be used occasionally, I would not use it more than one out of 10 times if at all. John |
Post# 1196431 , Reply# 3   1/2/2024 at 07:51 by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
If available, I'd stick with the sensor cycle for everyday use. If it doesn't, I'd go to normal cycle. |
