Thread Number: 95024
ge V12 |
Post# 1196705   1/8/2024 at 04:34 by aircub (Huntington, AR)   |   | |
hello i hAVE ACURED A 1963 V12 AND NEED to tighten belt does i need to be tight or some play in it and i am sure its the original belt? Darren |
Post# 1196706 , Reply# 1   1/8/2024 at 04:40 by Aircub (Huntington, AR)   |   | |
Post# 1196709 , Reply# 2   1/8/2024 at 05:50 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1196778 , Reply# 3   1/9/2024 at 03:38 by aircub (Huntington, AR)   |   | |
where do i get a belt? |
Post# 1196779 , Reply# 4   1/9/2024 at 03:41 by Aircub (Huntington, AR)   |   | |
Here is the belt!
Post# 1197214 , Reply# 5   1/16/2024 at 02:23 by aircub (Huntington, AR)   |   | |
just a question can i get a belt from a auto parts store or does it have to be a ge belt. Darren |
Post# 1197215 , Reply# 6   1/16/2024 at 06:17 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, the belt looks pretty good in your picture. You may just want to tighten it. You can use an ordinary belt from an automotive store or hardware store.
The same belt fits all GE filter flow washers including the T model plastic tub washers that came after it actually used the same belt, too bad you don’t live closer I would give you a belt I bet you I have 40 new ones that will never be used. There’s just no demand for them anymore. I might use one every few years GEs were not hard on belts the biggest thing that hurt them when the transmission started leaking oil and destroyed the belt. Your machine doesn’t look like it leaks oil that’s a good thing. John |
