Thread Number: 95057
Print for GSW9545 and or advice |
Post# 1197002 , Reply# 1   1/12/2024 at 20:43 by DADoES (TX, U.S. of A.)   |   | |
The main drive motor is running during instances of no drain? Or the machine exhibits no action? Your machine is a Resource Saver model. There is a drain valve. It energizes for drain. Water recirculates for the Spin/Spray Rinsing function in the Normal cycle when the valve isn't energized. The little circuit board is for the AccuWash water temperature sensor. |
Post# 1197009 , Reply# 2   1/12/2024 at 22:17 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Both the timer and the drain valve were weak parts on this machine. Unfortunately I have a slightly different version that I like a lot but it’s not my main washing machine it’s used once or twice a month is all and still works great.
Post# 1197156 , Reply# 4   1/14/2024 at 22:59 by DADoES (TX, U.S. of A.)   |   | |
Post# 1197161 , Reply# 5   1/15/2024 at 06:22 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes, the lid switches are very common problems on direct drive washers just replace it or if you want to bypass it that’s up to you if there’s no small children around to play with the machine.
If you would have described the problem as it just stops dead at the end of the wash cycle. I would’ve said lid switch. I still replace a couple of those lid switches every week we buy them by boxes of 25 at a time. It really helps to describe a problem accurately as it happens we have the same problem with customers every day. John L |
