Thread Number: 95092
/ Tag: Wringer Washers
Miele 75T wringer washer |
Post# 1197447   1/20/2024 at 08:22 by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
This morning I was driving passed a second hand shop. I noticed there was a wringer washer standing outside. I had to stop and have a closer look. It was a Miele 75T complete with Miele wringer. It is a semi automatic machine that works with a thermostat and automatic start when the selected temperature is reached. This was the TOL of the Miele wringer washers. The TOL Miele twintub had the same semi automatic system. Both were very expensive machines. At this moment in my life I don't need a wringer washer, but goodness I was tempted!
Post# 1197448 , Reply# 1   1/20/2024 at 08:31 by ozzie908 (Lincoln UK)   |   | |
Post# 1197473 , Reply# 3   1/20/2024 at 14:20 by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Austin, no I didn't ask. I just made pictures and went on my way. No need to get more tempted. lol
Tom, Miele didn't have a stick, but tongs. I'm not sure if it was included in the price. Here's a picture.
Post# 1197500 , Reply# 4   1/20/2024 at 17:16 by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 1197510 , Reply# 5   1/20/2024 at 18:25 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
In action!
One either used wringer or spin dryer for extraction, each sold by Miele. Drain hose on washer found by Louis obviously has been changed from original. Its red color indicates a modern type meant to cope with hot to very high water temperatures. nat.museum-digital.de/object/118... www.automaticwasher.org/c... Late 1940's early 1950's one still could get a Miele washer with tub made of wood. Miele also offered a round tub wringer washer, the mighty W 155. More than 250,000 units of this model were manufactured during the period of its production from 1945 to 1967. artsandculture.google.com/asset/... Timeline of Miele appliances: www.miele.com/en/com/time... By 1950's washing machines in Germany began moving out of wash houses and basements into main living areas. Miele's square cabinet top loading washers reflected that change. You saw this across Europe as other manufactures also brought out square tub and compact wringer washers. |
Post# 1197511 , Reply# 6   1/20/2024 at 18:32 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
For those wondering, yes, Miele did have washing machines that burned solid fuel for heating.
No. W 307 comes to mind. This washer could use any source of fuel for heating: coal, city gas, propane, electricity and steam. www.miele.com/en/com/time... https://www.ebay.de/itm/181933933326... |
Post# 1197514 , Reply# 7   1/20/2024 at 18:48 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
But one can find older washers by Miele and others without looking too hard in Germany. Ditto for ironers and other vintage laundry appliances. Most go for very little money.
www.kleinanzeigen.de/s-an... www.kleinanzeigen.de/s-kunst/mie... |
Post# 1197518 , Reply# 9   1/20/2024 at 18:56 by luxflairguy (Wilmington NC)   |   | |
Question! While these were semi-automatic, O.K., but the wringer was hand cranked? Interesting!!! Greg |
Post# 1197519 , Reply# 10   1/20/2024 at 19:07 by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 1197520 , Reply# 11   1/20/2024 at 19:19 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Washers with manually powered wringers were easier (and cheaper) to design, build, etc.... Power mangles require some sort of transmission or other mechanism to get power from main motor, or perhaps had one of their own.
These washers were "semi-automatic" as such one didn't need to provide wash action. That and many did have timers which would stop wash action. Add a pump and there you are.... |
Post# 1197523 , Reply# 12   1/20/2024 at 19:50 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
If one had to chose one would go with Servis Superheat washer.
Servis offered greater capacity tub and a power wringer. @Vacbear58 What you've got a hold of there is famous Miele W 477 If one ever shows up on this side of pond I'm having it! www.automaticwasher.org/c... |
Post# 1197607 , Reply# 13   1/21/2024 at 15:51 by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
If it’s the same styling it’s most likely an older machine than the W477. For instance a T WA 500.
Post# 1197619 , Reply# 14   1/21/2024 at 16:41 by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 1197740 , Reply# 15   1/23/2024 at 08:35 by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1197831 , Reply# 16   1/24/2024 at 12:07 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1197832 , Reply# 17   1/24/2024 at 12:09 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
