Thread Number: 95152
/ Tag: Vintage Dryers
Need help with 1973 Hotpoint dryer squeaking |
Post# 1198013 , Reply# 1   1/26/2024 at 20:29 by appnut (TX)   |   | |
Post# 1198047 , Reply# 2   1/27/2024 at 09:03 by Jr2712 (Maracaibo-Zulia-Venezuela... )   |   | |
Hi, I'm not the most experienced member here but I think maybe the rear drum bearing needs lubrication or replacement. When gets hot it expands and generate more friction.
Hope it may help... and not be too wrong. JR. P.s. Bob I'm your fan, your answers in other threads had helped me a lot. Thank you. |
Post# 1198052 , Reply# 3   1/27/2024 at 09:36 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Most likely, the rear bearing is worn out, if you caught it early enough, it just needs the little plastic Teflon sleeve, once the sleeve wears away it becomes a metal to metal condition and squeaks quite a bit. The bearing does not normally get lubricated.
The front drum slides could also be starting to fail. If you want to use the machine regularly it should be disassembled and cleaned Front and rear bearings inspected as well as the bushings for the idler pulley. Also clean the motor very carefully so the motor doesn’t overheat from the buildup. John. |
