Thread Number: 95170
/ Tag: Vintage Dishwashers
90’s whirlpool washer |
Post# 1198184 , Reply# 1   1/28/2024 at 20:54 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The wash tub can lean for a number of reason. Sometimes the whole frame is bent a little bit from the machine being dropped. Sometimes you can add a spring. If it really bothers you to pull it over a little bit. It’s usually not the three centering springs.
It could’ve had the tub swapped although I tend to think it’s original if you bought a replacement tub they always substitute a white one, so that would not have been a new replacement tub but someone could’ve taken it out of another Machine. |
