Thread Number: 95214
/ Tag: Vintage Dryers
What's making my dryer smells like charcoal lighter fluid |
Post# 1198554 , Reply# 1   2/4/2024 at 14:03 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Also, is it gas or electric?
If it happens to be a gas dryer, and you’ve done any painting or cleaning in your house clothing that is dried in the dryer when there’s a background odor in the house will have a very strange smell charcoal, lighter fluid is a good description in fact, even electric dryers, will leave a smell in your clothing if there’s any different background odor in the house. If it’s an electric dryer, there’s no cause of concern. If it’s a gas dryer and you haven’t used any cleaners or paint or anything in the house and it continues for multiple loads over a few weeks. You might have the dryer checked by a service technician. John . |
Post# 1198556 , Reply# 2   2/4/2024 at 14:11 by 2011hoovermatic (owosso michigan)   |   | |
It's electric Here's a picture of the model number. Thanks.
Post# 1198560 , Reply# 4   2/4/2024 at 14:35 by 2011hoovermatic (owosso michigan)   |   | |
Thanks everyone. |
Post# 1198594 , Reply# 5   2/5/2024 at 06:50 by turquoisedude (.)   |   | |
For what it's worth, I had a similar situation with my 1957 GE electric dryer - clothes had a smell vaguely like burnt gasoline. In my case, it was the centrifugal heater switch in the main motor that was burning and the smoke was being drawn into the clothes drum. I'd suggest pulling the dryer and inspecting all connections for anything that looks like it may be overheating - discoloured or bubbled insulation at a connector for example. |
Post# 1198599 , Reply# 6   2/5/2024 at 12:23 by Maytag85 (Sean A806)   |   | |
The only time I had a dryer produce a burning smell is when the wire between the high limit thermostat and heating element on the Maytag DE306 was on the fritz, immediately turned it off and cut power as soon as I caught it. Still have this dryer, but has since been customized.
