Thread Number: 95704  /  Tag: Vintage Automatic Washers
Center Dial Maytags - Atlanta Area North
Post# 1203431   4/14/2024 at 14:17 by kenw (ATL)
I have an LA208 Washer, regular (smaller) capacity, 2 speed motor, and an LDE608 Electric Dryer with electronic moisture sensing. The L is the color code for Almond. I am located north of Atlanta, GA in Canton, GA. I had a local gent that was an experienced repairman who has maintained them. He has happily retired, and I am looking for someone or a company that might have experience with the older machines. I know that some of the members are in the Atlanta Metro area, and I am hoping that a member may be able to recommend a repairman. I recently repaired an injector on the washer, but I would like to have a professional for bigger jobs. Thank you!
Post# 1203545 , Reply# 1   4/16/2024 at 12:36 by kenw (ATL)
Maytag LDE608 Electric Dryer, Thumping Sound
I have a Maytag LDE608 Electric Dryer with electronic moisture sensing. The L is the color code for Almond. It has developed a thumping sound. Not too loud, but seems to thump with every drum revolution. Would this possibly be a roller or glide issue? Many thanks, Ken
Post# 1203551 , Reply# 2   4/16/2024 at 14:03 by qsd-dan (West)
qsd-dan's profile picture
May be a loose baffle if it's every drum revolution.
Tear it apart check the baffles, drum rollers, glides, belt, idler pulley, and front/rear felt seals. I'd also check the plastic blower wheel as these strip after racking up the miles. Also a good idea to blow the motor out with compressed air and clean the cabinet up.
Here's how to remove/install the front panel, front bulkhead, drum, and belt.
Post# 1203612 , Reply# 3   4/17/2024 at 07:51 by thatwasherguy (Kentucky)
What kind of shape is the belt in?
thatwasherguy's profile picture
In the past, I've also seen a worn belt that was starting to come apart smack against the inside of the machine, and create a very similar symptom.
Hope this helps,
Thatwasherguy.
Post# 1205046 , Reply# 4   5/9/2024 at 16:52 by kenw (ATL)
Dryer Fix
Thank you gsd-dan, and thatwasherguy! Thatwasherguy, you were right. It was a shredded belt. Thanks, Ken
