Thread Number: 37705
KDS 20 Superba V needs cleaning |
Post# 561017 , Reply# 1   12/3/2011 at 17:09 (4,527 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 561023 , Reply# 2   12/3/2011 at 17:34 (4,527 days old) by labboy (SD, CA)   |   | |
If the water feed tube for the top rack is OK, I would look at the valve/flapper in the check valve. Replacing this made a major difference in upper wash arm performance in my KDS22.
It is easy to replace. In the attached thread there is a picture of the valve and the GE part number. I believe I paid about $5 for the replacement valve. CLICK HERE TO GO TO labboy's LINK |
Post# 561027 , Reply# 3   12/3/2011 at 18:39 (4,527 days old) by rp2813 (Sannazay)   |   | |
Post# 561028 , Reply# 4   12/3/2011 at 18:55 (4,527 days old) by labboy (SD, CA)   |   | |
Post# 561031 , Reply# 5   12/3/2011 at 19:02 (4,527 days old) by DADoES (TX, U.S. of A.)   |   | |
Reversing-motor units do have a check valve. What they don't have is a solenoid-activated drain valve, which is on the non-reversing motor units. Check Valve is Item # 11 The GE substitute flapper is WD1X1486. |
Post# 561059 , Reply# 7   12/3/2011 at 22:31 (4,527 days old) by DADoES (TX, U.S. of A.)   |   | |
