Thread Number: 50484
KDS-19 trouble - parts - help? |
Post# 726986 , Reply# 1   1/11/2014 at 14:14 (3,757 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Bill and welcome to automaticwasher.org, yes the complete service manual is located here:
KitchenAid 19 Series Dishwasher Service Manual and the parts list: KitchenAid 19 Series Dishwasher Parts Catalog |
Post# 727119 , Reply# 3   1/12/2014 at 01:37 (3,756 days old) by barcoboy (Canada)   |   | |
Did you take the actual detergent dispenser doors out and clean the shafts and the openings where they pass through the door? Also, it's probably not a bad idea to change the two o-rings for the doors, as this is very easy to do. The link below is a thread I wrote when I changed them in my KDS-58, which is a portable version of the KDS-18, which I believe uses the same detergent dispenser.
If you have the front cover off, watch the two bi-metals when the timer activates them to see how much they are flexing... mine moved quite a bit... if they don't move enough, they might need to be replaced. Also, when the bi-metal releases the door, it should snap open very quickly... if it does not, that means you have a broken spring, or the shafts/opening are gunked up and need cleaning. CLICK HERE TO GO TO barcoboy's LINK |
Post# 727392 , Reply# 5   1/13/2014 at 09:46 (3,755 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The most obvious suspect is the heater/drying blower motor which would only activate during drying. Like any motor, it would suffer from needing service and/or bearings. Happily, they can be found regularly, used if anything. Heck, the blower/heater assemblies were popular to pull and use for home brew drying cabinets due to their compact nature . Should be simple to service!
Thanks for saving another example of Kitchenaid's finest! RCD |
