Thread Number: 66737
New to Group with New to me Maytag E2L |
Post# 893990 , Reply# 1   8/15/2016 at 07:21 (2,811 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
If you use the search function and keywords "Maytag Wringer" pages and pages of excellent advice on these machines will turn up, including various restoration tips from those that have "been there and done that".
As you'll find out from reading various archived posts, a trail of oil on the rear left leg can mean a leak. www.automaticwasher.org/cgi-bin/T... www.automaticwasher.org/cgi-bin/T... |
Post# 894027 , Reply# 2   8/15/2016 at 13:39 (2,811 days old) by CrazieEddie (at the very edge...)   |   | |
Thanks Laundress, I had a quick look at the link on leaks and it's just what I needed! |
Post# 894033 , Reply# 3   8/15/2016 at 14:36 (2,811 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 894038 , Reply# 4   8/15/2016 at 15:05 (2,811 days old) by bradross (New Westminster, BC., Canada)   |   | |
Hello Pat,
And let me extend a welcome to you as well! I have an E2LP also - a little newer than yours (1977), so my rolls are still in great shape. However, I have rejuvenated very old rolls for two of my 1935 Model 30s. As long as the rubber is in basically good shape and hasn't got major nicks or cracks, after cleaning, you may consider sanding them lightly with 80 grit sandpaper. Often the harder bottom roll will have a "crusty" surface that can be smoothed beautifully with sandpaper. Regarding shining up the tub interior, SOS pads and a lot of elbow grease can do wonders. If there is significant oxidation, 120 grit fine sandpaper works beautifully, followed by a buffing with Mother's Mag and Aluminum Polish (which is great for the crown also.) Avoid sanding the crown unless there is significant damage or corrosion. If so, only use a very fine, wet sandpaper, followed by Mother's. I've attached a pic of mine, showing what an amazing shine can be achieved.
Post# 894039 , Reply# 5   8/15/2016 at 15:07 (2,811 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 894093 , Reply# 6   8/16/2016 at 02:01 (2,810 days old) by Stan (Napa CA)   |   | |
Welcome aboard.
The oil down that leg is not un common with these old machines. Sometimes they'll leak a little when their transported (Up right or on their side) If you have to transport on its side, it's best to lay it face down (MAYTAG logo down) You could clean up the leg and the crossbar underneath near the weep hole, and run the machine and see how it goes. You may want to check and see if your agitator comes off and goes back on properly. Check your lint screen, then fill it with hot water, and see if the tub holds water, check to see if the tub to pump hose is leaking, pump works, and drain hose is O.K. Hopefully she's good to go! Let us know how it goes from there. |
