Thread Number: 76712
A Vintage Bank Holiday Weekend August 2018 |
Post# 1005678   9/1/2018 at 05:47 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And another year has flown and we are meeting up at Als Emporium over our final August Bank Holiday of 2018, as plans go with vintage appliances "There Are No Best Laid Plans" we had thought that this hols would be an open showcase of everything shipshape and tickety boo but life goes on and time runs away...So a small gathering of the "Get Stuff Sorted" party ensued and another work and fun weekend took place.
Link to previous New Washerroom Build thread.. CLICK HERE TO GO TO chestermikeuk's LINK |
Post# 1005679 , Reply# 1   9/1/2018 at 06:00 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Getting stuck into the Line of Hotpoint Toploaders are Steve (SESteve) and Danny, this 1502 toploader was given to us by Mark Hill who he and his dad ran one of the last Hotpoint Service centrs in and around Norfolk and
Mark moved to Malta last year. Its a solid machine and is one of the quietest every made having a cast gearbox which the later series didn't.
This post was last edited 09/01/2018 at 09:01 |
Post# 1005680 , Reply# 2   9/1/2018 at 06:09 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And heres Phil (ServisSlimline) and Chris (ServisChris) getting stuck into their (and mine) favourite laundry appliances. This was Servis UK first front load auto washing amchine. Its was sold as the "Most Compact" at only 22.5 inches wide and still taking a 9lb washload, given the Bendix Giromatic wash in a 30inch cabinet this fitted into British homes with ease. Its needing a new door boot and bearing which are still original from 1972.
Post# 1005681 , Reply# 3   9/1/2018 at 06:13 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Meanwhile outside on the patio we are getting stuck into spinners wringers and an AEG Favorit Dishwasher which will be fitted into the 1970`s all original AEG Electric Sink Unit complete with fitted dishwasher and automatic washer and tumble dryer.
L - R Ian (Triumphdolomite) Richard (Ricky5050) Darren (Slowspin66) and Mather (Keymatic3203)
This post was last edited 09/01/2018 at 09:02 |
Post# 1005683 , Reply# 4   9/1/2018 at 06:35 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Heres Jon (LavamatJon) getting ready to sort out the wall of Miele.
Post# 1005684 , Reply# 5   9/1/2018 at 06:44 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Heres me n Steve getting stuck into the "Tub in and out" scenario , we got the outer tub painted last time but a little leak on the tub bellows had us hauling it out to do a more permanent repair.
Post# 1005685 , Reply# 6   9/1/2018 at 06:45 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1005686 , Reply# 7   9/1/2018 at 06:56 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
With the washer outside we took the tub apart, now Steve has done many repairs on these machines and I like others said was always daunted by how to take it all apart, which was quite easy when the teacher is methodical and says "Right, Your Turn" lol..
Here we see the top console flipped over onto a chair so we don't need to disconnect all hoses n wiring , with inner tub removed we proceed to taking out the outer vitreous enamel tub, this was the last series for the 1970`s with metal tub, from this point on until the 90`s the outer tub was polypropylene. |
Post# 1005687 , Reply# 8   9/1/2018 at 06:58 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Proceeding to wirebrush and sand down the affected parts ready for the chemical metal compound the epoxy paint and sealant.
Post# 1005688 , Reply# 9   9/1/2018 at 07:00 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
With chemical metal curing we turn our attention to the inner tub, the cast balance ring on atop need rubbing down and painting !!
Post# 1005689 , Reply# 10   9/1/2018 at 07:02 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
This inner drum is a really thick heavy drum made of vitreous enamel. Quick rub down and primer paint applied.
Post# 1005690 , Reply# 11   9/1/2018 at 07:09 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Meanwhile Phil and Chris move onto another Servis that appeared to throw water out, so the lads went into diagnostic mode but then it appeared to cured itself , bizarre, but hey its a vintage appliance.
This post was last edited 09/01/2018 at 09:03 |
Post# 1005691 , Reply# 12   9/1/2018 at 07:12 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
The AEG sink is having a thorough test after needing an inlet valve and pipes along with work done on the main pump n motor, this will sit under the sink as a design unit.
Post# 1005693 , Reply# 13   9/1/2018 at 07:18 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Meanwhile its time for "more tea and cake vicar"...Matts Battenburg cake was such a hit last time that supplies were requested along with Steves Millionaires Shortbread...
Post# 1005694 , Reply# 14   9/1/2018 at 07:22 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
In the old washroom here are the appliances stacked up ready for the "Spa of Ian" treatment, plenty of hot water and elbow grease to finally get rid of the builders dust. !!
This post was last edited 09/01/2018 at 09:04 |
Post# 1005695 , Reply# 15   9/1/2018 at 07:25 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Ready to start re-assembling the Hotpoint toploader. Outer tub on, heater clamped and sealed and new pump canvas drive fitted and sealed to outer tub. !!
Post# 1005696 , Reply# 16   9/1/2018 at 07:27 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Tub clamped and slower seal fitted, now to tighten and place top hat bellows over drive block in the inner tub...
Post# 1005698 , Reply# 17   9/1/2018 at 07:29 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
A prior shot is the spin race bearing sited on the drive block to where the inner tub sits..
Post# 1005699 , Reply# 18   9/1/2018 at 07:34 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Inner tub in situ with tub block and over bellows fitted...now for a water test. The Hotpoint uses a small low down agitator block to fit under the base of the plastic Spiraclean agitator.
Post# 1005700 , Reply# 19   9/1/2018 at 07:35 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Which is one of these beauties...
Post# 1005701 , Reply# 20   9/1/2018 at 07:41 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Meanwhile...Richard gets stuck in to plumb in the AEG Electric sink..
Post# 1005702 , Reply# 21   9/1/2018 at 07:45 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And the Creda spinners are being renovated using a donor machine 3 into 2...A new brake connecting rod for Richards and my squealing brakes adjusted..
These are cast iron bases to which a copper drum is mounted spinning at 2,800rpm. |
Post# 1005704 , Reply# 22   9/1/2018 at 07:51 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Well its time for dinner, the day goes so quickly at these meets. Al has been busy in his new kitchen preparing a meal for the workers. And all ready and keeping warm in the "Hostess Trolley"...
Post# 1005705 , Reply# 23   9/1/2018 at 07:58 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
We were all so hungry to eat I forgot to take food pics, anyone please add !!
So next day all here for breakfast.. This post was last edited 09/01/2018 at 09:05 |
Post# 1005708 , Reply# 24   9/1/2018 at 08:14 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
So after breakfast a few of us went over to Garys place to collect a few machines he was passing on, that's the beauty of this hobby, fix up, restore and recycle.
So Jon & Danny in one car and Mikey n me in together and guess what we all saw at a crossroads and immediately there was a screech of brakes... On many petrol forcourts are these vending laundry systems, From Kis Laundry systems come an 8kg and 18kg washing machines, soft mounted with fast spins and an 18kg tumble dryer, they dispense autodose Amway detergent. CLICK HERE TO GO TO chestermikeuk's LINK This post was last edited 09/01/2018 at 09:07 |
Post# 1005710 , Reply# 25   9/1/2018 at 08:20 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And back from Garys with said appliances., Hotpoint twin tub for Jon, Servis twinny for Ian and a Hoover wringer washer and Spin a Rinse..
This post was last edited 09/01/2018 at 08:47 |
Post# 1005711 , Reply# 26   9/1/2018 at 08:22 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Meanwhile, washers fixed its time to "Load n Watch"..
This post was last edited 09/01/2018 at 08:48 |
Post# 1005712 , Reply# 27   9/1/2018 at 08:25 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Mr Shifters at the ready..
Post# 1005714 , Reply# 28   9/1/2018 at 08:27 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hotpoint being put back and Phil n Chris move onto the Hoover 800 1970`s classic, new motor, hoses and mains cord...
Post# 1005715 , Reply# 29   9/1/2018 at 08:29 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
The AEG dishwasher coming together, sink plumbed so next up is...
This post was last edited 09/01/2018 at 08:49 |
Post# 1005716 , Reply# 30   9/1/2018 at 08:31 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
get the Twintubs wringers and spinners out and proceed to check all working ...
Post# 1005718 , Reply# 31   9/1/2018 at 08:39 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Next restore is Jons Hotpoint Microprofile washing machines from 1986, Jons busy sorting out his new washer room and on checking this needs new bearings, so as we know a man who can..
1000 spin, 10lb washload, computer controlled with liquid crystal display, from the 1980`s New Generation range of Hotpoint UK Laundry,
Post# 1005719 , Reply# 32   9/1/2018 at 08:42 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Bearings in the Hotpoint Ice Diamond purple or amethyst freezer...
Post# 1005720 , Reply# 33   9/1/2018 at 08:45 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And heat gun at the ready to warm up old bearing for easier extraction...the beauty of these machines is that the front panel comes off for easy maintenance.
Post# 1005721 , Reply# 34   9/1/2018 at 08:52 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1005723 , Reply# 35   9/1/2018 at 08:58 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Bearing out, chamber fine ready for a clean up and new bearings fitted !!
Post# 1005724 , Reply# 36   9/1/2018 at 08:59 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
And the old rusty relic bearing, not bad for an original from 1986...
Post# 1005725 , Reply# 37   9/1/2018 at 09:00 (2,064 days old) by Rolls_rapide (.)   |   | |
"Coo-ee Mr Shifter...!" (A reference to the Brooke Bond PG Tips tea adverts - with the chimps!) CLICK HERE TO GO TO Rolls_rapide's LINK |
Post# 1005728 , Reply# 38   9/1/2018 at 09:13 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1005729 , Reply# 39   9/1/2018 at 09:15 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
new bearing out the freezer and just slides into the warmed support tube !!
Post# 1005730 , Reply# 40   9/1/2018 at 09:18 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Spider and drum in great condition with the use of green box powder...
Post# 1005731 , Reply# 41   9/1/2018 at 09:28 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
All back together, notice the motor is mounted on top of these Hotpoint machines..
Post# 1005733 , Reply# 42   9/1/2018 at 09:33 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Door seal on, ready for a test wash...
Post# 1005734 , Reply# 43   9/1/2018 at 09:40 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
All sat sitting, its "Wine o Clock" time wash in, 95d boil wash with citric acid...
Post# 1005735 , Reply# 44   9/1/2018 at 09:43 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Last job of the weekend is to fix a new resistor which had burned out on the Hoover Keymatic
Post# 1005736 , Reply# 45   9/1/2018 at 09:45 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
With the Holzer timer removed it was cracked open and the old resistor removed and a new super duper one fitted.
Post# 1005737 , Reply# 46   9/1/2018 at 09:50 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
All that we need to do now is to re-fit the timer and test, this was late in the evening and will be water tested next time...
Post# 1005738 , Reply# 47   9/1/2018 at 09:54 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
A few pics of old and new, and See You Next Time, many thanks to Al for hosting another easy on working weekend and a big Thank You to all who attended and for all your work effort.
Post# 1005757 , Reply# 48   9/1/2018 at 12:23 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
We are all just saying how time flie, this time last week it was "Wine o Clock" time, Enjoy Your Weekends everyone ...
Post# 1005758 , Reply# 49   9/1/2018 at 12:24 (2,064 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Cheers Steve...
Post# 1005763 , Reply# 50   9/1/2018 at 13:14 (2,064 days old) by triumphdolomite (Staffs(UK))   |   | |
I'll just say my thanks to Al too for another great weekend and to you Mike for creating another great thread to remember it by. Ian ps. The Supertwin 111 did wonderfully on Tuesday's wash! |
Post# 1005796 , Reply# 51   9/1/2018 at 18:13 (2,063 days old) by jersey-johny (Jersey City / Fort Lauderdale)   |   | |
FANTASTIC! Good god that was well done fellas - you really did it up! Thanks all for sharing -
Truly, you can see and feel the sense of accomplishment and camaraderie from 3500 miles across the Atlantic! Love all those Twinnies - they seem to still be pertinent over there more than they are here. Have to ask: whats the bank holiday you guys are celebrating? Type of Labor Day, like us on Monday? And please urgently send over some of Steves Millionaires Shortbread..."tickety boo!" |
Post# 1005798 , Reply# 52   9/1/2018 at 19:47 (2,063 days old) by Blackstone (Springfield, Massachusetts)   |   | |
That phrase means something entirely different (in U.S. history) than what you are celebrating.
When Roosevelt took office as president in 1933, at the depths of the Great Depression, one of his actions was to close all the banks for a period of time, to prevent panic withdrawals. Hence, the term "bank holiday". I'm assuming your holiday is nothing of the sorts. |
Post# 1005817 , Reply# 53   9/2/2018 at 02:48 (2,063 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
On a very basic level "bank holiday" on both sides of pond pretty much break down to same thing; days when banks are closed and or employees are given off/paid OT if they do work.
For instance the last Monday in August is "bank holiday" in England/Wales. en.wikipedia.org/wiki/Bank_holid... While first Monday in September is Labor Day and a "bank holiday" in that the Federal Reserve is closed, which by extension means so are nearly all other banks in the USA. Labor Day is also a national holiday in that many (but not all) businesses are closed. In a way both serve one same purpose, they extend summer holidays by a bit. |
Post# 1005818 , Reply# 54   9/2/2018 at 02:53 (2,063 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Morning Ian, glad the Servis twinny is up n running, a bit taller than the others , save on the back..
Post# 1005819 , Reply# 55   9/2/2018 at 03:05 (2,063 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello Johny and welcome to the club and madhouse, yes its good to get together and sort stuff out, as with anything vintage they always need a little coaxing and nurture..
Yes the twintub washers where a staple of UK laundry rooms and kitchen, compact and easy to move around, and probably why UK housewifes were the last in the field to move to automated laundry appliances. My fav is the Servis models being the ones mum and family had..
Post# 1005820 , Reply# 56   9/2/2018 at 03:14 (2,063 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello Fred, thanks for the explanation of your Bank Holiday, its easy to dismiss as just a holiday without realising the significance. It is a tradition when our banks and companies shut down for a workers holiday.
Its the last holiday for us so everyone tends to make more of it especially as in August - which is usually or hottest month but alas this year cloudy and rainy... |
Post# 1005821 , Reply# 57   9/2/2018 at 03:29 (2,063 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Morning Laundress, thanks for the explanation, hope all good with you, we where discussing the etiquette of laundry having discussions with our younger attendees, and your knowledge of washday laundry was talked about, all good !!
Enjoy your Labour Day Monday !! Traditionally washday...
Post# 1005824 , Reply# 58   9/2/2018 at 04:53 (2,063 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1005875 , Reply# 60   9/2/2018 at 18:55 (2,062 days old) by petek (Ontari ari ari O )   |   | |
Post# 1006070 , Reply# 61   9/4/2018 at 14:57 (2,060 days old) by richardc1983 (Leeds, UK)   |   | |
Wow Al, the house looks really wonderful and the wash house amazing. What a fabulous presentation of machines through the years. I've got the same radiator in my bathroom, they belt out some right heat.
Looking forward to coming down again to see you some time. I don't come on here much due to work commitments but hoping you are keeping well. Richard |
Post# 1006075 , Reply# 62   9/4/2018 at 16:01 (2,060 days old) by turquoisedude (.)   |   | |
