Thread Number: 82971
Looking for MAYTAG WASHER Lubrication Instructions |
Post# 1072239 , Reply# 1   5/13/2020 at 00:49 (1,045 days old) by qsd-dan ![]() |
![]() 3
What are you trying to lubricate?
The only place where traditional grease is used on a Maytag automatic washer made after 1965 is a small dab on the suspension springs/eye bolts and under the cap of the lug stop mechanism on the transmission pulley. Otherwise, you can sort of pack grease in the pulley bearing if you want to fight with it. Depending on the brake package bearing design, (most of these are sealed) you may be able to re-pack them but a good quality new bearing, like an NSK is only around $10 and not worth the hassle of cleaning and re greasing IMO. Just replace. Silicone grease is used for the motor carriage rollers/glides and damper pads. Gear oil is used inside the transmission. (Properly choosing the correct transmission oil varies depending on location and temperature swings where the machine will be subjected to) Turbine oil is used for the motor bearings, pump bearings, tub bearing. Brake package uses gear oil but only required when it starts squealing during the braking portion of the spin cycle. I use Vaseline on the triangular tub cover seal before installing the band clamp. It makes for a perfect seal the first time around without rushing the job and making mistakes, like other methods using Windex. |
Post# 1072508 , Reply# 3   5/14/2020 at 14:23 (1,043 days old) by hobbyapocalypse ![]() |
![]() 4
is sold in the Zoom-spout oiler. There are different flavors but look for "turbine oil" or "turbine lubricating oil" on the label. Hardware stores should have it.
Post# 1072823 , Reply# 4   5/16/2020 at 13:50 (1,042 days old) by LowEfficiency ![]() |
![]() 2
MaytagBeliever, what machine model are you working on?
Be aware that some lubrication guidance has changed over the years, and the correct answer may depend not only on what machine you have, but the age and style of the replacement parts as well. Maytag superseded things like the tub seals several times, for example, with completely different materials and lubrication instructions in the process. A different discussion for reference: www.automaticwasher.org/c... Also, adding on to Dan's list, if using non-Maytag gear oil, you would specifically want to use a non-hypoid gear oil. Hypoid gear oil typically contains sulphur-based pressure and wear additives that are corrosive to the yellow metal bushings in the transmission case. Genuine transmission oil is still readily available as well. |
Post# 1072894 , Reply# 6   5/16/2020 at 22:16 (1,041 days old) by LowEfficiency ![]() |
>> Where can I buy the Zoom Spout Oil?
Amazon is probably the easiest way, but your local hardware store might carry it. Do heed the fine print of hobbyapocalypse's post though - Not all Zoom Spout oil is turbine oil - some, such as the "white" varieties or anything marketed for sewing purposes, are of a thinner viscosity. "Zoom Spout" is just a trade name for the style of bottle that the oil comes in. ("Extendo", for example, is a competitor). |
