Thread Number: 84763
Picked up the Maytag GA310 and cracked it open. Is it worth using? |
Post# 1092248 , Reply# 1   10/6/2020 at 23:55 (902 days old) by LowEfficiency ![]() |
![]() 2
>> Is this thing ready for the scrap yard?
Not at all. An old Maytag won't even flinch at that amount of rust. Here's a few photos of the rust on my A408, before and after cleaning it out. We picked this machine up two years ago intending for it to be a parts donor, but have been using it as-is full time ever since. www.automaticwasher.org/c... Your agitator shaft is in great condition, and you have the two-speed motor, so both are good finds especially for the price (free). And you have the lint filter without a fabric softener dispenser - That was a cheaper option at the time, but they are neat to have now. As long as the tub seal seals up OK when you re-assemble, you should be good to go. Good luck! |
Post# 1092295 , Reply# 3   10/7/2020 at 13:19 (902 days old) by RP2813 ![]() |
![]() I think that scraping sound involves the inner and outer tub spacing being out of adjustment. The fix, IIRC, is sort of a trial and error thing since the tolerance is fairly close. Others here with more experience can advise.
I agree that your machine has plenty of life left in it. As you know, these old Maytags are built like tanks. I wouldn't be concerned with energy consumption. These machines were consistently rated by Consumer Reports as the most energy efficient top load washers available at the time. |
Post# 1092318 , Reply# 5   10/7/2020 at 15:52 (902 days old) by goatfarmer ![]() |
Post# 1092324 , Reply# 6   10/7/2020 at 17:59 (901 days old) by qsd-dan ![]() |
That 310 is roaring like a freight train on spin which almost always points to a bad radial bearing. A new one from Whirlpool will be Chinese made, here's a much better option.
CLICK HERE TO GO TO qsd-dan's LINK on eBay |
Post# 1092325 , Reply# 7   10/7/2020 at 18:11 (901 days old) by combo52 ![]() |
![]() This machine is still workable, you can either fix anything wrong with it and just use it or go for a Huge Project and restore it.
It does sound like the lower ball bearing is noisy, you can replace it if you like but the machine will work just fine with a noisy bearing if you don't mind the noise.
I would not take the wash basket out unless you want to restore the machine.
To completely restore this washer you could put in anywhere from 25-over 100 hours of work and several hundred dollars, it is worth it if you want to do it but depending on your resources buying a new Speed Queen TC5000 might be a lot cheaper and will certainly last much longer do a better job and use a lot less energy.
Post# 1092330 , Reply# 8   10/7/2020 at 19:20 (901 days old) by wa9aLqTh (Bay Area Northern California)   |   | |
Do you have any instructions for replacing the radial bearing? |
Post# 1092331 , Reply# 9   10/7/2020 at 19:27 (901 days old) by qsd-dan ![]() |
You'll have to remove the brake package to access the bearing. There's a special tool to remove the brake but others here have used creative methods to get around it. I personally use the tool, myself.
CLICK HERE TO GO TO qsd-dan's LINK |
Post# 1092343 , Reply# 10   10/7/2020 at 20:57 (901 days old) by wa9aLqTh (Bay Area Northern California)   |   | |
Thanks! Radial bearing ordered. Do you recommend conditioning the rubber hoses and tub seal with silicone lube? My goal is to squeeze another 10 years out of this machine, not to restore it. I’ll probably clean off the rust with naval jelly and spray paint the inside with Rustoleum. |
Post# 1092346 , Reply# 11   10/7/2020 at 21:21 (901 days old) by qsd-dan ![]() |
I personally have never used silicone as a restoration technique, I just replaced these parts back when they were all over Ebay and inexpensive. I did have an old seasoned Maytag repair men recommend wiping older stiff hoses up and down with solvent until they softened up. I tried it once on a 40 year old drain hose, it kind of worked.
I apply a thin coat of petroleum jelly around the tub seal so it doesn't get pinched when tightening down the metal band. You could probably use silicone there. Make sure the grooved area of that triangle seal faces outward (I face it upward for verification) or it'll leak. You'll also need to properly and evenly space the tub cover. If it's pushed too far down it'll scrape the top of the inner tub or completely jam it during the spin cycle. |
