Thread Number: 94017
Miele WXD160 WCS washer questions |
Post# 1187111 , Reply# 1   8/8/2023 at 03:59 (264 days old) by Labboy (SD, CA)   |   | |
Post# 1187115 , Reply# 2   8/8/2023 at 07:48 (264 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Miele washing machines sold in USA for domestic use have and need both hot and cold water inlets. This is because some times machine will fill with hot or needs to blend that temp with cold to get "warm". This and if machine senses hot water temp is too high it will blend cold water to temper.
Previously one could just use a "Y" connector and simply control water temp from faucet. Long as washer was getting water from both valves it was satisfied. Modern Miele washers with motherboards still need both hot and cold water connections, but one can program washer to be "cold water only" Unless things have changed reprogramming washer to "cold water only" will not alter energy settings. That is for cycles that call for hot water fill if machine is programmed to "cold water" it will fill with whatever temp water comes from tap but will *NOT* engage heater. Thus if a "Cottons/Normal" cycle called for filling with hot water and no use of heater that is what it still will do even if reprogrammed to "cold water only". Again could be wrong so please check with Miele USA for confirmation. www.atticmag.com/2013/10/... www.manualslib.com/manual/120747... www.mieleusa.com/pmedia/ZGA/TX20... www.reddit.com/r/Miele/comments/... |
Post# 1187116 , Reply# 3   8/8/2023 at 08:00 (264 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1187153 , Reply# 4   8/8/2023 at 17:32 (263 days old) by Brisnat81 (Brisbane Australia)   |   | |
In the 240v world, that setting just changes whether the machine is H+C or C only fill. We have solar hot water, so in summer I have it set to H+C and in winter I change it to cold only. The difference being the starting temp of the water, the final temp is as set |
Post# 1187161 , Reply# 5   8/8/2023 at 21:11 (263 days old) by miatadan (Sudbury)   |   | |
I live in Canada, not sure whether hot water heater will work or not. I am hooking up to bathroom faucet because I am in an apartment, no access to separate hot and cold faucets. Dan |
Post# 1187221 , Reply# 6   8/9/2023 at 18:52 (262 days old) by Labboy (SD, CA)   |   | |
Post# 1187224 , Reply# 7   8/9/2023 at 20:09 (262 days old) by miatadan (Sudbury)   |   | |
Thanks Bill I feel comfortable to order the Miele now. Dan |
Post# 1187225 , Reply# 8   8/9/2023 at 20:52 (262 days old) by Labboy (SD, CA)   |   | |
Post# 1187228 , Reply# 9   8/9/2023 at 21:16 (262 days old) by miatadan (Sudbury)   |   | |
Bob Where are you located ? Canada or USA? I have the manuals, but it did not have answer about hot water heater when only using cold water inlet. This for the help Dan |
Post# 1187255 , Reply# 10   8/10/2023 at 08:52 (261 days old) by Labboy (SD, CA)   |   | |
