Thread Number: 94094
/ Tag: Wringer Washers
Maytag Wringer N2LPS |
Post# 1187941 , Reply# 1   8/18/2023 at 21:31 (259 days old) by Stan (Napa CA)   |   | |
It cleaned up good!
If u post serial # someone here will date it for you. I’d guess 70’s I’ll look at my service manual to see about lubricant for wringer. You already know how to set the wringers apart when not in use.. Sounds like it’s ready for a maiden Voyage. Spot with cleaning Barkeepers Friend may get rid of the rust spots HTH |
Post# 1187942 , Reply# 2   8/18/2023 at 21:45 (259 days old) by Stan (Napa CA)   |   | |
From owners manual
Post# 1187945 , Reply# 3   8/18/2023 at 23:04 (259 days old) by qsd-dan (West)   |   | |
Post# 1188154 , Reply# 6   8/22/2023 at 02:30 (256 days old) by Stan (Napa CA)   |   | |
With some adjusting you should be able to get the pump wheel to engage.
While machine is off..Look under it and operate the pump lever on and off, you’l be able to see what going on there and possibly what may need a little lubricant. The rod should be threaded to adjust length to get it to catch…I remember correctly. A drop it two of oil on the roller hangers may help the squeak. Do you have a service manual for this machine? There is a downloadable one here in the forum. Post a video for us if u can, we love success! |
Post# 1188246 , Reply# 7   8/22/2023 at 22:38 (255 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
Post# 1188520 , Reply# 9   8/25/2023 at 20:04 (252 days old) by mt999999 (East Liverpool, Oh)   |   | |
On the serial number, it only contains the 6 numbers; no letters. I uploaded a photo of the sticker here. With 60 Hz instead of cycles, I'm assuming that this is a post 1970 model, perhaps?
Post# 1188598 , Reply# 11   8/26/2023 at 22:36 (251 days old) by ea56 (Cotati, Calif.)   |   | |
Good for you Micheal! Doing laundry in a Maytag Wringer washer can be a very rewarding experience. In no time you can have a weeks worth of laundry washed, rinsed, wrung out and hanging to dry. Yes, its a lot of hands on work, but the time goes by quickly with the end result being a sense of accomplishment, plus immaculately clean laundry. I hope that you are enjoying your new toy.
Eddie |
Post# 1188644 , Reply# 12   8/27/2023 at 14:29 (250 days old) by ozzie908 (Lincoln UK)   |   | |
