Thread Number: 91019
/ Tag: Wringer Washers
My new E2L Maytag Wringer with pump |
Post# 1155331   7/27/2022 at 16:31 (638 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
Picked her up yesterday! The pastor asked $30, I gave him $35. Thank you all for the nudge to take a chance on this one.
And thank you all who have been down this road already and blazed a trail that those like me can follow. I have already read much of Larry's great write-up and am looking forward to discovering the write-ups others have done. We tipped her forward to move and noticed oil drips following us across the floor and up the steps. The rear leg looks like it's been dripping a long time. We should have tried to keep her upright all the time but nobody even thought of that! All I did so far is use soap and water to remove the surface dirt, and parked the wringers apart. They have some slight damage where they were stuck together. The model number on the red sticker says E2L. I thought the pump models are E2LP? Have not yet attempted to power her up. First I want to try turning the mechanism by hand to see that everything moves freely. Should it turn fairly easily by hand with the agitator and wringer engaged? And will the lower wringer turn when not under tension but the drive control handle is engaged? The motor has a 3-prong plug. Is this original? If I decode the serial number correctly (11482XR), September 1965. It seemed like a good idea to start this new thread on the story that began in Shopper Square at the link below -- CLICK HERE TO GO TO hobbyapocalypse's LINK |
Post# 1155333 , Reply# 1   7/27/2022 at 16:43 (638 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1155335 , Reply# 2   7/27/2022 at 16:55 (638 days old) by ea56 (Cotati, Calif.)   |   | |
What a great deal! And it sure cleaned up nice too! Its fortunate that the agitator was stored off the post, otherwise it would have probably been stuck on. To keep it from sticking on the post coat the post with a thin film of Vaseline, and periodically reapply the Vaseline to maintain a coating that will keep it lubed. Always store the agitator off the post like it is in the photos.
The three prong plug was probably original, by ‘65 most large appliances were equipped with 3 prong plugs from the factory. As far as the model number not including the “P” to designate that it has a pump is nothing to be concerned about. Its clear that it came equipped with the pump from the factory. Maybe Maytag didn’t start using the “P” in the model numbers until later than the ‘65 model run? You should have lots of fun with this wringer washer. They are excellent machines. Congratulations on your excellent score! Eddie |
Post# 1155337 , Reply# 3   7/27/2022 at 17:08 (638 days old) by rpms (ontario canada)   |   | |
Post# 1155340 , Reply# 4   7/27/2022 at 17:38 (638 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
I too wonder what it was used for, and how awkward it must've been to use in that corner spot. If I find out I'll let you all know!
When I was there yesterday I noticed an 8x11 instruction card tacked on another wall for a Maytag A407 I think it was, so apparently they also had an automatic machine there at one time. It was a card that came with the machine and I'm sorry I didn't tell anyone to not throw it away. It could be collectible. |
Post# 1155342 , Reply# 5   7/27/2022 at 18:10 (638 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1155369 , Reply# 7   7/28/2022 at 04:35 (637 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Meant to mention in other thread you should keep Maytag wringer washers upright as possible during transport, but figured you'd find that bit out on your own.
Either way bit of oil leaking isn't bad thing. To be clear it's largely grease Maytag packed into wringer head and elsewhere that is liquifying. At some point machine will need to be torn down, gunk cleaned out, and fresh grease packed in, but these machines were so well built (or over built) can go some time before that is necessary. Much will depend on how much use your machine sees going forward. My copy of Maytag wringer service manual states machines in use for commercial purposes wanted overhauling more often than all but the heaviest domestic use. As for rollers and "damage" once you've got things sorted out and do maiden wash you can see how if at all rollers are prevented from doing their job property. You can remove shallow flat spots or marks on rubber wringer rollers by giving them a wipe with kerosene soaked rag, then quickly washing them down. Kerosene will clean, soften and remove bit of layer on rubber wringer rollers. Thus would sort out "damage" problem, and was suggested method for both power hand hand cranked wringers. Only thing is one shouldn't do this often. Best thing was to prevent wringer rollers from sticking together turning storage from start. This or you can search eBay and other sources for NOS Maytag wringer rollers. There is still quite a bit out there some going for not very much money. Depending upon your situation may only need to replace the white or black roller, but not both. If still original (and likely are), you may want to consider replacing water seal, agitator, stop ring https://www.ebay.com/itm/373217900493... https://www.ebay.com/itm/373217898584QUE... You may also wish to buy the newer turquoise agitator to use instead of black which came with your washer. This was final design by Maytag for agitators used in their wringer washers, and features a cup design underneath that helps keep water from seeping down shaft and into transmission. The Amish who use and love Maytag wringer largely only use the newer turquoise agitator over any of others. cottagecraftworks.com/maytag-wri... |
Post# 1155370 , Reply# 8   7/28/2022 at 04:45 (637 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My Maytag "Gryator" washer is even earlier (1962) and has three pronged grounded plug.
www.automaticwasher.org/c... Owners manual does speak to using a grounded adapter for washers with two prong plugs, and IIRC stresses machine should be grounded. This includes not removing ground pin or trying to use washer with two prong plug. Pump: My J2L makes no mention of pump by model number, but it's got one. IIIRC pumps when became available were an add on feature for Maytag conventional washers. Some households loosened up the mouse trap and sprung for the things to be installed on new orders, others stuck with simple gravity drain. Even with pump installed Maytag wringer washers will still drain via gravity. Indeed owners manual states after wash day is done and machine drained to lower hose to ground. This will drain out remaining water in sump and hose. |
Post# 1155371 , Reply# 9   7/28/2022 at 04:48 (637 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Someone long ago likely nabbed that Maytag A407 from church. A modern Maytag automatic was worth more to many than the wringer, so the latter remained I suppose.
The A407 could have been taken away when RC church closed Holy Ghost church and priests vacated rectory. Maybe it was sold, donated to another parish, taken by order to their new mission... www.automaticwasher.org/c... |
Post# 1155372 , Reply# 10   7/28/2022 at 04:57 (637 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
"I too wonder what it was used for, and how awkward it must've been to use in that corner spot. If I find out I'll let you all know!"
Once you start working with that Maytag wringer you'll notice how well things could have gone in it's former setup. Countless households or laundries had similar arrangement. Washer in spot (even corner) then on other side series of wash tub(s) or sink(s). You moved things down a production line as it were; Wring from washer into first rinse tub/sink. Swish things about then move onto second sink/rinse tub. Haul things back into washer to wring out either onto lid (that's one of reasons it's there), into a basket, first sink/tub emptied of water, or some sort of solid surface placed over first wash tub Not a Maytag, but you get the idea.. Once you've got yourself sorted doing wash with a wringer becomes a rhythmic almost "Zen" experience. |
Post# 1155416 , Reply# 11   7/28/2022 at 19:01 (637 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
Launderess, thank you for all the helpful hints. My agitator might be the new design even though it's the old color. Tell me what you think.
This post was last edited 07/28/2022 at 19:25 |
Post# 1155589 , Reply# 14   7/30/2022 at 19:11 (635 days old) by bradross (New Westminster, BC., Canada)   |   | |
I've had my E2LP for almost 13 years, and I thought I had got a great deal at $100 ! I love hearing about these "saves", especially if there's a bit of a background story to it. Mine came from an elderly lady in Tacoma, Washington, who bought it new in 1977. She wanted it to go to somebody who would appreciate it, and I bought it through her grand-daughter. It was in practically "like new" condition.
Post# 1155597 , Reply# 15   7/30/2022 at 23:03 (634 days old) by qsd-dan (West)   |   | |
Post# 1155610 , Reply# 16   7/31/2022 at 02:29 (634 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Video shows how it's done with manual tubs instead of stationary sink(s).
Video in Post# 1155372 shows how important it is to feed things through wringer flat as possible. Easier said than done with shorter things like face, hand or even bath towels. Larger items like sheets, blankets, and quilts are another matter. Latter is at least one instance some actually liked that foot pedal Maytag had on last incarnation of wringer washers. By controlling wringer stopping and starting via foot pedal both hands were left free to sort out wash. Here is an example with Speed Queen wringer. Maytag's wringer is self adjusting so there's nothing to loosen or tighten. What holds true however is like above if something isn't wrung dry enough to suit, can always refold and send back through mangle again. Personally after mangling bung things into either one of the spin driers or washing machines for final extraction. Even best wringing only equals about 240 rpm speed speed. That might be fine if one is hanging things on (a very strong) clothes line or horse to dry, but since often will be using tumble dryer... |
Post# 1155612 , Reply# 17   7/31/2022 at 02:37 (634 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
"Scroll through the archives and look for the "Big 3" experts (Geoffdelp, E2L-arry, BrassRoss). Their wisdom will properly guide you in the right direction."
Yes, it is always wise to wander off into the archives. So much great information by those who went before. In particular things like using modern "grease" or "oil" instead of buying old cans of Maytag product that my have been sitting around for god knows how long. Happily Maytag center seal grease is still available new. Bought a tube of the stuff when first got my Maytag wringer to lube points as directed in manual. This includes putting a bit now and then on center post/spline area instead of Vaseline. www.maytagreplacementpart... |
Post# 1155756 , Reply# 18   8/1/2022 at 23:04 (632 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
Yes it looks like this is a poly agitator. It is somewhat flexible and has the cup feature that Launderess mentioned.
The casters are in fair shape, wheels almost like new but metal parts more or less rusty. One of the locking ones was the worst, rusted in the locked position but I was able to work it loose. I reinstalled the casters but would like to try derusting them as I make progress. Would evapo-rust be safe to use on them? I removed the motor to clean and oil but I don't think it has oil ports. It does seem to run fine as is, but could use a cleaning. Also I thought about replacing the v-belt, it looks deformed and not as flexible as it should be. When I turn the flywheel by hand the agitator shaft and wringer go thru their motions and everything seems to move smooth but tight. I'm wondering if this tightness is just due to the normal bearing preload, or if the old oil has turned to jello. The pump does feel too tight. I will try hot water and see if that loosens it up. I am having a great time searching the archives, learning from the experts. The service manual at Cottage Craftworks is a helpful guide as well. |
Post# 1155765 , Reply# 19   8/2/2022 at 00:29 (632 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Owners manual along with parts/service book for Maytag wringer washers can be downloaded from AW library.
Last time one looked at my copy of service manual for Maytag wringer no mention was m made for oiling or otherwise lubricating motor. Could be wrong, so may have a look when have spare moment. If washer has sat sitting for decade or more yes, things are bound to be tight. Belt may also need attention from sitting so long. In all cases condition in basement would also determine how bad things may be. Personal point of view is to run machine once or few times (with water) to see what there is. If you get heavy to moderate oil/grease leaking down rear leg, wringers aren't preforming well as they should, ditto for pump, transmission and so forth, at least you know where you are. With that list in hand can go about setting up a plan for action including acquiring necessary parts. As for pump being "tight" who knows what crud might lurk inside. *LOL* Build-up of lint, hard water deposits, detergent or soap residue may be gumming up the works so to speak. Regarding the casters, whatever you decide to use to treat metal bits I'd keep it clear of actual wheels unless sure won't cause harm. Even with full tub of water Maytag wringer washers should glide rather easily. When empty mine requires little more effort than push with finger to move it about. One could do that wearing a frilly apron, starched shirtwaist and cha-cha heels if desired. *LOL* |
Post# 1155766 , Reply# 20   8/2/2022 at 00:33 (632 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
@R11
Yes, that is black poly Maytag agitator with "new" design.
Post# 1155768 , Reply# 21   8/2/2022 at 00:38 (632 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
"They were less likely to dull from washing compounds, such as chlorine bleach and didn't break/crack if accidentally dropped."
Welcome to my world! |
Post# 1155770 , Reply# 22   8/2/2022 at 00:46 (632 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Actually am gobsmacked at how well mend of above agitator has held. Done many a wash day with it and so far it's been champion. This even though have another exactly like it in undamaged condition (seller sent replacement for one that was damaged in shipping), so that's two I've got of same. Mainly use them because like the lint filter/detergent dispenser. Know should be using the turquoise one with modern design, but sometimes one just want's a bit of drama on wash day.
Post# 1155772 , Reply# 23   8/2/2022 at 00:48 (632 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1155790 , Reply# 24   8/2/2022 at 08:24 (632 days old) by swestoyz (Cedar Falls, IA)   |   | |
Wow, congrats on such a beautiful find! Your E2 looks to be in fantastic shape. I agree with Geoff regarding the rollers in that they don't look too bad. You are oh so lucky to have found a late 1965 model w/ a black poly agitator. What I wouldn't give for one... :)
I also don't have any additional advice beyond what has already been provided. Change out that center seal now BEFORE using the washer. I wish I had done the same with my '62 and it sits idle now with water in the transmission until I have time to tear it down for a full rebuild. Ben |
Post# 1155843 , Reply# 25   8/3/2022 at 01:36 (631 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
What? You don't think sisters, brothers, nuns, monks, priests, etc.. have laundry?
*LOL*
Post# 1157647 , Reply# 27   8/22/2022 at 22:49 (611 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
The drain hose is so stiff it won't unbend to allow all the water to drain out. I don't even have to hang the nozzle on the bracket. The hose stands up by itself. So to avoid having to replace the whole hose/nozzle assembly I plan to see if I can remove the nozzle from the hose and find a new flexible hose that will fit the pump and nozzle.
The stop ring came off in 2 pieces so I know I need a new one of those. And after reading some of the stories, I decided to also replace the water seal before I even fill the tub with water. So I'll be ordering those 2 parts. Also I plan to order the set of 5 gaskets for the transmission and wringer head, and maybe the tub gasket too. The casters cleaned up very nice after just soaking overnight in Evapo-Rust. Now they lock and unlock the way they should. See the before and after of one of the casters. Photo 5 is inside one of the adjustable legs. Good thing I took that pic before removing the legs to clean. Don't know if I would've guessed the right way to put those curved nuts back on! Assuming this one was on the right way when I got it, ha! |
Post# 1160249 , Reply# 28   9/23/2022 at 19:05 (580 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
To quote Launderess, Mustn't rush these sort of things.
Well I cut the nozzle off the old drain hose to reuse if I can, but in the meantime just rigged up something from what I had lying around. It's not pretty but it works and is meant to be temporary. See pictures below. I cut a short piece off the old drain hose and boiled it for an hour to soften it some, and attached it to the pump outlet. Then I took a few feet of old garden hose and a short piece of 1/2-inch copper pipe. Then I pressed the pipe into the garden hose and the garden hose into the old drain hose, and hose-clamped it all together. So I was ready to do the first water test, just enough to cover the tub bottom, and saw no leaks except a tiny bit from the pump. Whether from the shaft or from between the housing and cover I couldn't tell but it was only wet not dripping. Put on a new V-belt, a 31-inch like I thought it should be, and it was too tight to get the dimension that the repair manual calls for. I noticed in the forum that others have had the same experience. To compensate I just put a thick piece of rubber over the pad and spring that the motor rests on. So then I ran her under power finally and everything seems to run smoothly, but the agitator does move some even when disengaged. I remember seeing something about that on the forums but haven't looked it up again yet. Also cleaned the wringer, it was filthy under the rollers. And I tried to clean up the rollers from where they were stuck to one another in various places. First I scraped, then sanded, then wiped down with a kerosene rag and then washed off the kerosene. They didn't come out as beautiful as expected, but I hope I did them some good. Lastly, I ordered the new water seal and other parts from Cottage Craft Works, and I have a question about the water seal that I couldn't find addressed in the forum. The repair manual says, "When replacing the water seal, lubricate top of the seal with a small bit of grease..." So is this correct? I would think maybe the bottom of the seal should be greased but, the top? |
Post# 1165606 , Reply# 29   12/4/2022 at 23:36 (507 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
This past weekend I did my first load of wash in the White Ghost! And it was my first experience ever using a wringer machine! I don't remember ever actually helping my grandma using her wringer washer.
The only real trouble I had was things wrapping around the rollers if I didn't reach around to pull them as they came out after the rinse. Nothing stuck to the rollers after the wash, tho. Maybe the soap suds keep things from sticking. Anyway, I thought the handbook must have something to say about this, and sure enough it does. It says if you fold the leading edge of an item so that it's a little thicker, it won't stick to the rollers. I'll have to try that next time. She seemed to run well, with just a slight noise like a vibration somewhere. Hope it's nothing to worry about at this point. Please forgive my wall in the photo. It's not all as ugly as that section but of course that's the best spot for the washer right now! Well I'm very happy to be able to share this occasion with you all who have helped me so much. Not only that but this is the only place where I can talk about this without being laughed at.
Post# 1165616 , Reply# 30   12/5/2022 at 02:07 (507 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
