Thread Number: 91246
Suggested replacement for Miele W1986? |
Post# 1157561 , Reply# 1   8/21/2022 at 18:21 (705 days old) by littlegreeny ![]() |
Hopefully someone here knows where you can find a new pump. If not, I suggest you go with another Miele since you are used to the European way of fabric care now. Their W1 washers with TwinDos automatic detergent dispensers are wonderful. I have the WXR/TXR860 set which is quite pricy but to me it's worth having the touch screens and the ability to customize the options and then save my favorite cycles.
Post# 1157589 , Reply# 2   8/21/2022 at 22:32 (704 days old) by combo52 ![]() |
Post# 1157818 , Reply# 5   8/25/2022 at 08:03 (701 days old) by Launderess ![]() |
While Miele does or did produce many parts in house for their appliances, not everything comes under that heading.
Often pumps, timers, solenoid valves and other bits came from third party manufacturers. Pumps for Miele washers of 19XX and before vintage usually were made by Hanning. www.directrepair.eu/drain... Sadly MieleUSA tech/customer support is no longer what it once was, so getting any information via telephone or online regarding details about parts or installation is largely verboten. To best of my knowledge W19XX series washing machines by Miele sold in USA used 230v-240v pumps at 50hz www.automaticwasher.org/c... https://www.ebay.com/itm/164003880712... m.ebay-kleinanzeigen.de/s-anzeig... My Miele washer is older than yours, and thus have spent more hours than care to recall sat sitting in front of computer researching and otherwise running spare parts to ground. If you've not done so already suggest pulling electrical schematic papers from washer (should be just inside front door when swung open), and see what there is about wiring/power supply to pump. |
Post# 1157843 , Reply# 7   8/25/2022 at 14:41 (701 days old) by richnz (New Zealand)   |   | |
the drain pumps are interchangeable between dishwashers and washing machines. Older WAMA seem to have a fan of sorts on the back but newer ones don’t. I don’t know what its like where you live. |
Post# 1158221 , Reply# 10   8/29/2022 at 22:47 (696 days old) by littlegreeny ![]() |
Post# 1158298 , Reply# 11   8/31/2022 at 04:11 (695 days old) by richnz (New Zealand)   |   | |
Interesting that this is a 90w pump. Did it have to lift water to a particular height. Look on eBay at Miele dishwasher pumps. They might not have the same 90w but they might just do the trick. |
Post# 1158325 , Reply# 12   8/31/2022 at 14:16 (695 days old) by Launderess ![]() |
Buy another Miele 19XX washer in good to excellent condition to use as parts donor.
capecod.craigslist.org/app/d/den... |
Post# 1158327 , Reply# 13   8/31/2022 at 14:26 (695 days old) by Launderess ![]() |
Post# 1158661 , Reply# 16   9/4/2022 at 13:50 (691 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i would reccomend this top load washer since it has good cleaning and rinsing power
www.maytag.ca/en_ca/washe... |
Post# 1158710 , Reply# 18   9/5/2022 at 05:19 (690 days old) by henene4 ![]() |
Like, in 5% of the times it would tangle anyway. If I mixed the sheets in, it would tangle most likely and once something tangles something, some patch will always damp. If nothing major tangles, everything gets dry. It just happened to happen once every now and then something caught something and then one or two items remained damp. |
Post# 1158839 , Reply# 20   9/6/2022 at 04:57 (689 days old) by askolover ![]() |
Post# 1158942 , Reply# 22   9/6/2022 at 21:41 (688 days old) by askolover ![]() |
Post# 1159104 , Reply# 23   9/9/2022 at 03:05 (686 days old) by richnz (New Zealand)   |   | |
Does it turn freely? It can be taken apart by pulling off the fan part (Not the impeller end). There are two long screws that hold it together that can be undone with pliers. |
Post# 1159173 , Reply# 24   9/9/2022 at 21:37 (685 days old) by Launderess ![]() |
Post# 1159223 , Reply# 25   9/10/2022 at 15:10 (685 days old) by scottsb (New Jersey)   |   | |
@richnz Yes, it turns freely. Why would I take it apart? Not sure I follow? |
