Thread Number: 94014
/ Tag: Classified Ad Finds
GE Power Shower |
Post# 1186917   8/5/2023 at 16:39 (267 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1186929 , Reply# 1   8/5/2023 at 19:09 (267 days old) by bradfordwhite (central U.S.)   |   | |
I wonder if this is a model with the cute little mini spray arm under the silverware basket. The "power scrub" I think it was called.
I found one of these in the early 80s. It ran but had a golf ball sized rust hole in the tub very near the motor so.... But before sending it off to the metal recyclers I was sure to take out the mini spray arm and hose that fed it along with a few other parts. |
Post# 1186930 , Reply# 2   8/5/2023 at 19:42 (267 days old) by appnut (TX)   |   | |
Post# 1186941 , Reply# 3   8/5/2023 at 20:33 (267 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Power-Shower was the mini wash arm under lid that sprayed water downwards.
Silver-Shower was a small wash arm off main lower that directed spray of water up towards silverware basket. IIRC this was a TOL feature that came with General Electric's last gasp of top loading dishwashers. Like everyone else they soon ditched that design in favor of loading from front. www.automaticwasher.org/c... |
Post# 1186942 , Reply# 4   8/5/2023 at 20:38 (267 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
" It ran but had a golf ball sized rust hole in the tub very near the motor "
Rust holes at bottom of these GE Mobile Maid tubs were common enough. Mine came with one as well. Patched it up with JB Weld marine bond and that was that, it's held up ever since. www.automaticwasher.org/c... Problem was the inner tub liner used by GE (Plastisol) wasn't most durable. One crack or dent and water worked its way between liner and metal outer tub lead to rust that could spread like cancer. Why GE stuck with Plastisol long as they did for dishwasher interiors one does not know. |
Post# 1186947 , Reply# 5   8/5/2023 at 21:24 (267 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It’s greatly reduced cost to manufacture, and most of all because it greatly reduced expensive damage claims because of porcelain chipping.
Porcelain chip complaints nearly put KitchenAid out of business, we used to scrap so many brand new dishwashers because they had chips tanks. And the problem got really bad when they KD 18 series dishwashers were released because they took the gasket off the edge of the door and customers would drop a dish on the edge of the door and made a nasty chip and there was no way you could get out of having to replace the entire door in warranty. This is why whirlpool and Frigidaire cleverly went to a molded plastic inner door because of the durability of it. GE was always a low level dishwasher until the 80s when they actually got serious about building dishwashers and one that actually cleaned and was fairly durable. John. |
Post# 1186949 , Reply# 6   8/5/2023 at 21:29 (267 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1186962 , Reply# 7   8/6/2023 at 07:14 (266 days old) by turquoisedude (.)   |   | |
