Thread Number: 94230
'70 Maytag A806 oil leak - What do I do next? Please help |
Post# 1189245   9/3/2023 at 22:54 (243 days old) by AtomicT (Middletown, NY)   |   | |
So I followed this wonderful site's direction on how to replace the tub bearing and stem kit, but I need to fix the leaking oil situation on my '70 Maytag.
We stopped using it 5 years ago, after 6 years of almost daily use because it was vibrating, sounding off and leaking oil. So I've got it apart and have the parts for the tub bearing stem, and the damper pad kit. But what do I need to do, and what parts to I need, to fix the leak? Are there threads here I can research on what to do? Am I rebuilding the transmission? I just need to know as I am clueless on the next steps....
Post# 1189251 , Reply# 1   9/4/2023 at 01:24 (243 days old) by stuftrock1 (Kentucky)   |   | |
Post# 1189256 , Reply# 2   9/4/2023 at 08:29 (243 days old) by AtomicT (Middletown, NY)   |   | |
Post# 1189259 , Reply# 3   9/4/2023 at 09:56 (243 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1189263 , Reply# 4   9/4/2023 at 10:13 (243 days old) by AtomicT (Middletown, NY)   |   | |
Post# 1189270 , Reply# 5   9/4/2023 at 11:57 (243 days old) by LowEfficiency (Iowa)   |   | |
>> Are there any threads on here detailing on how to disassemble and reassemble the transmission I could look at? Oh yeah - the thread linked below is solid gold. "Rebuild of Maytag Transmission and Transplant into LAT 9800 AAW." www.automaticwasher.org/c... |
Post# 1189274 , Reply# 7   9/4/2023 at 12:08 (243 days old) by Maytag85 (Sean A806)   |   | |
Post# 1189277 , Reply# 8   9/4/2023 at 12:13 (243 days old) by Good-Shepherd (New Jersey)   |   | |
Maytag brake assemblies rarely fail. Aside from adding a tablespoon of trans oil to the brake package I'd leave those items alone. |
Post# 1189295 , Reply# 10   9/4/2023 at 16:16 (242 days old) by qsd-dan (West)   |   | |
Maytag used an o-ring seal from at least 1956 (may even go back to the AMP models) until June 1986 when they switched to the lip seal design that ran until Maytags demise in 2006.
The trans needs to be taken apart....at minimum, change the old oil (what's left of it), and replace the lower o-ring. Back when parts were still easily available, changing the Delrin pinion gear and clutch washers was also recommended. You'll need to use RTV for the transmission cover seal since the gasket is NLA. Running the machine with low oil will eventually gull up and seize the internal gearing. |
Post# 1189301 , Reply# 11   9/4/2023 at 16:39 (242 days old) by AtomicT (Middletown, NY)   |   | |
Post# 1189311 , Reply# 12   9/4/2023 at 17:59 (242 days old) by stuftrock1 (Kentucky)   |   | |
Post# 1189321 , Reply# 13   9/4/2023 at 18:27 (242 days old) by AtomicT (Middletown, NY)   |   | |
So, I have a tool i use for my car's oil filters. Its a nylon strap and a square 1/2" rod connecting the ends. I wrap it around the filter and then insert a ratchet into the rod and go to work. It works amazingly well. I think it might fit around the brake actually. Or i could just make my own I guess with a ratchet strap? |
Post# 1189324 , Reply# 14   9/4/2023 at 18:43 (242 days old) by Good-Shepherd (New Jersey)   |   | |
The brake doesn't need to be removed to take the trans out for service. You've got enough work already, don't fix things that aren't broken and unlikely to fail. |
Post# 1189351 , Reply# 15   9/5/2023 at 00:59 (242 days old) by qsd-dan (West)   |   | |
This is true but he mentioned in his first post about replacing the damper pads. Removing the brake assembly makes this considerably much easier to do. Something I learned with rebuilding transmissions early on is that the internal springs gets weak in the brake package overtime and it generally doesn't take long for the tub to begin indexing after the trans has been rebuilt and is agitating with great authority.
The brake tool were all over the place until Whirlpoop discontinued them a few years back. Almost overnight they suddenly became rare. I wonder if most owners threw them away after replacing the brake package or they were just stashed somewhere in the garage and forgot about 'em. Probably thrown away after they died, for sure. |
Post# 1189353 , Reply# 16   9/5/2023 at 06:13 (242 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1189369 , Reply# 17   9/5/2023 at 12:21 (242 days old) by LowEfficiency (Iowa)   |   | |
>> Almost overnight they suddenly became rare. >> ... >> Probably thrown away after they died, for sure. As a strong contributing factor, I don't think I've ever seen one marked in any way that indicates what it is. If a person had a history in appliance repair, they would recognize one of the specialty tools immediately (brake or tub nut tool). But for anyone else? Not a chance. Just another mystery tool. No idea what it is, no idea how to find out, no clue what it might be worth... but it looks kinda homemade, so... probably just junk. |
Post# 1189394 , Reply# 18   9/5/2023 at 17:31 (241 days old) by AtomicT (Middletown, NY)   |   | |
So, I went to my local appliance store to see if I could get some parts for this project. They went to get the owner of the store (who by the way said he was one of the first four members of this site!), and he went on to tell me that I am wasting my time on this. Here was his reasoning:
He stated that the lower O-ring should never fail. He state emphatically that it fails because the lower bushing has gone bad (he stated from the motor rollers go bad and put undo lateral stress on the lower trans housing). He explained that I was going to go through all of this and it was still going to leak anyways.
I am deflated for sure. Sourcing parts for this has been a circus show of jumping through internet hoops like crazy. So let me ask you all this:
What is a girl to do? I really really really want to put this machine back into service! (my dirty clothes are really stacking up!!)
Post# 1189401 , Reply# 20   9/5/2023 at 19:28 (241 days old) by qsd-dan (West)   |   | |
I've replaced a lot of o-rings is the last 16 years and never had a leak come back yet. They leak from a combination of use and age. One of our long term members, Geoff Delp scored a NIB A700 which leaked from the o-ring about a year into service. O-ring replaced, problem solved. Certainly no bushing wear on a virtually new machine.
Post# 1189406 , Reply# 22   9/5/2023 at 22:07 (241 days old) by stuftrock1 (Kentucky)   |   | |
Yeah that's a load of bologna. Those lower o-rings fail all the time, so much so that Maytag replaced them with a lower lip seal (which is compatible with your A806, just be sure to get the old o-ring out before installing the new lip seal). When I bought my A512, it had a minor oil leak. Installed a new lower lip seal and that fixed it. Hasn't leaked as much as a drop since.
Your A806 is still very much fixable, don't get discouraged! |
Post# 1189407 , Reply# 23   9/5/2023 at 22:11 (241 days old) by LowEfficiency (Iowa)   |   | |
Post# 1190704 , Reply# 24   9/26/2023 at 17:10 (220 days old) by AtomicT (Middletown, NY)   |   | |
Hey guys! I am still working on this. Life just keeps getting in the way!!
Anyways, I am looking for the agitator stop seal. Any leads on to where I can get one or at least a part number??
Any help would be appreciated!!
Post# 1190708 , Reply# 25   9/26/2023 at 18:19 (220 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1190724 , Reply# 26   9/26/2023 at 20:40 (220 days old) by Good-Shepherd (New Jersey)   |   | |
https://www.ebay.com/itm/385622761404QUE... |
Post# 1191180 , Reply# 27   10/3/2023 at 10:22 (214 days old) by AtomicT (Middletown, NY)   |   | |
So i am still plugging along on this and am near the end. I will post some pictures shortly. (My kids really enjoyed putting the transmission back together and pouring the oil!! )
I am replacing the water pump and noticed the stem for the bleach dispenser to attach to has no hole! The stem is there but its solid. So I am assuming that I just drill a hole? Is there a particular size I am supposed to use?
Thanks again to everyone for their help. This has been a really fun adventure.
One other question - After all of this, how long do you think it will realistically live for? |
Post# 1191181 , Reply# 28   10/3/2023 at 10:43 (214 days old) by qsd-dan (West)   |   | |
Use a 9/32 drill bit. It says that on the original package, maybe the new ones don't. One other question - After all of this, how long do you think it will realistically live for?
I did this 15 years ago and not one single problem has cropped up yet. Not surprised though, it's a Maytag. |
Post# 1191183 , Reply# 29   10/3/2023 at 11:01 (214 days old) by DADoES (TX, U.S. of A.)   |   | |
Bleach port on the pump ... yes, needs to be drilled. This 2020-21 thread discusses it starting at Reply 32 and references 9/32". |
Post# 1191191 , Reply# 30   10/3/2023 at 14:08 (214 days old) by stuftrock1 (Kentucky)   |   | |
Post# 1191519 , Reply# 31   10/7/2023 at 21:00 (209 days old) by AtomicT (Middletown, NY)   |   | |
So I have it all back together, cleaned up, and I think something is wrong.
First: I hooked it up in the garage for testing with just the one hose hooked up to cold with the settings set to cold, and water started shooting out through the hot inlet. Am I a fool for doing this or is it broken? I thought it was supposed to be closed if you only wanted to do cold water?
Second: I can't get it to spin. It agitates and does it beautifully and smoothly. When I have it set on the dial to do the spin, the machine just makes a semi-loud hum. I checked the wires on the motor and all is good. Any ideas on what's wrong?
Post# 1191525 , Reply# 32   10/7/2023 at 23:02 (209 days old) by Good-Shepherd (New Jersey)   |   | |
Yeah, both hoses should be hooked up. No spin: Is it plugged in via an extension cord? |
Post# 1191526 , Reply# 33   10/7/2023 at 23:35 (209 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1191538 , Reply# 34   10/8/2023 at 08:40 (209 days old) by AtomicT (Middletown, NY)   |   | |
Post# 1191540 , Reply# 35   10/8/2023 at 09:49 (209 days old) by AtomicT (Middletown, NY)   |   | |
